1993 Dodge Truck thermostat
1993 DODGE TRUCK
214,000 MILES • V8 • 4WD • AUTOMATIC
PK150
just need to change the thermostsat and don't quite know how to do it/where it is. I have the part and think I know where it goes but not too sure!?!?!
mj
Jan 21, 2009 at 9:46 AM
  • 110,244 POSTS
Hi:
Just follow the upper radiator hose back to the engine. It will end at the t-stat housing. Under the housing is the t-stat. Just drain the radiator, remove the upper hose from the housing, unbolt and remove the housing and remove it, remove the t-stat (note the direction it is sitting in) replace it, and reverse the order.
If you have problems or questions, let me know. Also, make sure there t-stat fits properly into the groves around the housing. If it's not in correctly, you could crack the housing when you tighten it. Also, make sure all old gasket material is cleaned off and the surface is clean and dry before replacing the housing.
Jan 23, 2009 at 11:41 AM
