1993 Dodge Truck
1993 DODGE TRUCK
190,000 MILES • V8 • 4WD • AUTOMATIC
SMOKIE43
When the fuel level in the tank drops below 1/2 full
the truck will start to run rough at an idle. The lower the fuel level get the worse this problem gets
it does not stall but will run very poor
Feb 8, 2008 at 11:27 AM
BLACKOP555
  • 10,386 POSTS
either your pumps filter is getting plugged or the pump is weak or you have a leak somewhere and the pump is not building enough pressure up. check the gas cap and fuel filler hose for cracks, also test the pressure of the pump at the fuel rail when the tank is full and when it is low.
Feb 8, 2008 at 11:45 AM
