1992 Dodge Truck Started Engine Then Died
110,000 MILES • V8 • 2WD • AUTOMATIC
AUTOREPAIR1
I turned the key and the engine started. Five seconds later the engine died. I thought it was the battery being that it was 20 degrees outside. I replaced the battery but all lights, buzzer worked as it did before I changed the battery out. I turn the key but no noise or anything happens.
Dec 27, 2009 at 12:20 PM
  • 75,988 POSTS
No cranking condition:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Dec 27, 2009 at 12:35 PM
