1992 Dodge Truck No spark
BLACKFOOT1
Electrical problem
1992 Dodge Truck V8 Four Wheel Drive Automatic 100k miles
Im not getting voltage to the pick up under the cap have replaced cpu relays , there are no wire breaks that i can see .
Oct 28, 2010 at 12:07 AM
WRENCHTECH
  • 20,760 POSTS
Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
Oct 28, 2010 at 1:52 AM
