1992 Dodge Truck Jerking after being driven for a while
131,000 MILES • V8 • 2WD • MANUAL
BLACKSTON33
I have a 1992 Dodge D150 pickup. After driving for a while it will begin to jerk as if choking down. I have replaced the plugs, wires, distributor cap, rotor, coil, and coil pickup. This has not helped. Any suggestions?
May 5, 2010 at 11:43 AM
HMAC300
  • 48,601 POSTS
clean your throttle plate on both side first. but also check for engine codes and fuel pressure, it may be low . ifit is change the fuel filter then check again it may have low pressure.
May 24, 2010 at 10:24 AM
