1992 Dodge Truck engine start up
148,000 MILES • V8 • 2WD • AUTOMATIC
CONFUSSED233
when the temp. outside is below 35 degrees,i turn on the ignition and the check engine light flashes and a sensor on the fenderwell clicks for about 3 min. when the check engine light stops the truck will start.i have taken the sensors inside at night and still does this is there a problem with a sensor somewhere else
Dec 6, 2009 at 9:45 AM
JDL
  • 16,098 POSTS
Welcome to the forum, might have been a relay making the noise? Which one was it? Any trouble codes?
https://images.2carpros.com/forum/automotive_pictures/170934_dodge_truck_relay_1.jpg
That view is under the hood, driverside fender lining. The info I looked at was W150-- 5.2 litre engine.
Dec 7, 2009 at 8:05 AM
