1990 Dodge Truck Wiper Motor
1990 DODGE TRUCK
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
SANDY1933
The wipers quit working. The fuse is OK. The wiper motor runs. I can move the blades by hand by 1 blade & both move. Is there an adapter of some kind between the motor and the wiper drive arms?
There are only 3 capscrews holding the motor to the firewall.
Dec 28, 2009 at 11:16 AM
CARADIODOC
  • 34,381 POSTS
There's a single link from the motor arm to the left wiper. That link popped off its ball and socket, usually on the motor end. You should need a pliers to pop it back on. If it comes off again, the nylon ball is worn out. I don't think you can buy just the nylon part. Look for a used linkage from the salvage yard.
caradiodoc
Dec 28, 2009 at 5:45 PM
