1990 Dodge Truck no spark no start
JSKIRP
Electrical problem
1990 Dodge Truck 6 cyl Two Wheel Drive 140000 miles
i was driving it backed up a hill shut it off went to start it nothing changed the oil pressure sensor,coil,pick up coil getting no spark from lead wire off coil to distributer were is the crank/camshaft sensors?maybe ignition control module cant find it either or ecm?????????????what could cause this vehicle to get no spark from the coil??/
Aug 1, 2009 at 2:20 PM
  • 110,244 POSTS
Are you getting power to the coil? As far as the crank sensor, it should be mounted to the timing chain cover near the harmonic balancer.
Oct 7, 2009 at 6:04 AM
