Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Truck
Ignition
No Spark
1990 Dodge Truck No Spark
1990 DODGE TRUCK
88,000 MILES • V8 • 4WD • AUTOMATIC
K_DM
MEMBER
1 POST
No spark from coil. Replaced dist. and coil. still no spark. Where would the problem be, ignition switch or computor
Jun 29, 2008 at 4:40 AM
BLACKOP555
Experienced Mechanic
when cranking the engine do you get a RPM reading?
or does it stay at 0?
if nothing you will need a new crank sensor probably.
if you get a reading i woudl check for +12v at the coil and i woudl check for a failed ignition control module.
Jun 29, 2008 at 6:12 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
