1990 Dodge Truck engine quits when it gets to operating tem
165,000 MILES • V8 • 4WD • AUTOMATIC
BFOX
90 Dodge Ram 150 with a 318 - Throttle body .
Truck starts when it gets to normal running temp it stalls .
Will not start till it sets for a good while .
It is running to rich .
Some one took all the air pollution equipment off .
It had single exhaust now it is duel with the original o2 sensor in .
Ran good then the Idle control actuator started acting up . could not get it to idle down .
Replaced it and was okay for a bit .
Now it does this .
Can codes still be pulled after the truck has been tampered with ?
Thank You for any help .
Mar 19, 2010 at 4:27 PM
BMRFIXIT
  • 19,053 POSTS
Looking for codes that effect it from running
check for spark and suspect bad coil
check hall effect switch in distributor
Mar 19, 2010 at 9:25 PM
