1990 Dodge Truck 4 wheel drive
150,000 MILES • 6 CYL • 4WD • MANUAL
HAILEYSPAPA
I have a 1990 Dodge truck that wont engage in four wheel drive. What do I need to check for this problem
Dec 21, 2009 at 7:59 AM
CH112063
  • 1,320 POSTS
(0% of the time the problem was related to the vacuum supply to an actuator. It has a vacuum hose that being exposed would fail. I would make sure it has its vacuum hose properly connected, first thing. You'll find this actuator on the front axle, ok, there is a very good instruction and complete troubleshooting explanation located right in this site, I would try to work with these instructions for all the problems you may come across. Excellent. ok.
Dec 23, 2009 at 2:19 PM
