The ignition intermittingly quits firing. The coil tests good.
Apr 22, 2009 at 1:02 PM
✓Experienced Mechanic
Intermittent or No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Apr 22, 2009 at 1:10 PM
