1987 Dodge Truck engine wont start
KENT H
Engine problem
1987 Dodge Truck V8 Four Wheel Drive 75000 miles
I replaced the ballast resistor after several wet clammy days when the truck would not start. The truck started right up and I ran it with no problems for 45 minutes. I was almost home when the truck sputtered and would not start up.The truck acted like it wanted to start but would not I changed the ballast resistor and nothing would happen. then I changed the control box and the truck would still not start HELP. 309-796-1887
Jan 17, 2008 at 8:37 AM
PEAR69
  • 1,482 POSTS
Check the distributer cap--the plugs--and plug wires. Be sure the plugs are gapped properly. Also check to see if you are getting spark.
Jan 17, 2008 at 2:58 PM
