Hi I have a 1987 Dodge Dakota. I had to replace the two brake lines that run from the front to the rear. I bled the brake and fluid comes out with no air. I can`t get a good brake now. The peddle is almost to the floor. I also replaced the rear wheel cylinders and brake shoes. I think this model has a control valve and the height sensing proportioning valve. I am not sure about how they work. I would appreciate any help you could give me.
Thanks
Thanks
Jun 30, 2008 at 1:38 AM
