1987 Dodge Truck
109,000 MILES • V8 • 4WD • AUTOMATIC
DODGETRUCK1987
motor getting hot boiling in overflow bottle white foam coming out of top of radiator coming out real bad when you put vehicle in gear replaced water pump and radiator and thermostat
Oct 8, 2008 at 10:27 AM
  • 110,248 POSTS
Hi:
It sounds like you have a head gasket problem. Check the compression. Also, theck the oil for water getting into it.
Let me know what you find.
Oct 8, 2008 at 2:06 PM
DODGETRUCK1987
hello joe thank you for your help i have not done a compression test since i got the vehicle running it has been sitting for 3 years it was flooded up too the windsheild with water i got the vehicle too run did a compression test during that time and every cylinder was 125 or better the motor runs real good no skip no smoke from exhaust motor does have some blowby i did check the oil for water and the oil is not milky white it is not looking normal but not sure if there is still water in motor also wondering if a cracked head is also possible along with head gasket again thank you for your help
Oct 8, 2008 at 8:35 PM
  • 110,248 POSTS
You're welcome. I'm sorry to give you bad news (head gasket) but that what I think it is.
Good Luck
Oct 8, 2008 at 11:29 PM
