1986 Dodge Truck vaccum hose connection
1986 DODGE TRUCK
126,000 MILES • V8 • 4WD • MANUAL
BLAIR383
connection to ac control crumbled, what is the proper sequence or pattern for the connector
Oct 4, 2008 at 6:57 PM
MERLIN2021
  • 17,250 POSTS
This is what I found, Federal for 5.2(318)
https://images.2carpros.com/forum/automotive_pictures/62217_Dodge_Vac_1.jpg
Oct 5, 2008 at 12:03 AM
SKEETR969
  • 7 POSTS
On the (bottom, front) inside of your hood, there should be a sticker that says which of Federal, Califormia or Canada your vehicle complies with. It also helps to know which V8, 318 or 360 in some cases, luckily the AC vacuum is simple for the most part and only changes between few styles -- early and late-model or V6 / V8, but some of the other components are in variable places. Some go to the ASRV solenoid before going to the manifold source and others go directly to the manifold source.
Oct 18, 2008 at 12:48 AM
