HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Truck
Engine
Symptoms
Not Running
1985 Dodge Truck Starting Problem
RDONALS
MEMBER
1985 DODGE TRUCK
V8
2WD
MANUAL
100,000 MILES
I turn the key and get no response, but the radio an every thing else works.
Tuesday, March 16th, 2010 AT 9:36 AM
MECHANIC
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good.
Tuesday, March 16th, 2010 AT 10:00 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1985 Dodge Truck Engine Won't Start
1985 Dodge Truck V8 Put Coil And New Wires On Why Don"t It Start
Asked by
dre100%
1 ANSWER
1985
DODGE TRUCK
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Crank And No Start. Pulled Transmission And Now Won't...
I Had My Truck In The Shop And I Pulled The Transmission Because I Had Clutch Problems. Put The Transmission Back In And Found That My Cps (...
Asked by
Shredder1212o
1 IMAGE
1993
DODGE TRUCK
Will Not Start
I Have A 1998 Dodge 4x4 Ram 1500. Lights Will Not Go Out. Truck Will Not Start. I Checked For Spark, Their Is Non. I Changed The Coil...
Asked by
bigsoko
1 ANSWER
1998
DODGE TRUCK
1999 Dodge 6cyl Van Will Not Start
Eng Cranks Will Not Start No Power To Coil, Switched All Relays Fuel Pump Comes On With Key Then Shuts Off Also No Power To C.B. Labled...
Asked by
wild bill 48
1 ANSWER
1999
DODGE TRUCK
1997 Dodge 1500 Series With A 318 Engine Will Not...
Was Driving Stopped To Let A Friend Out But Did Not Shut Off The Engine, Drove About A Half Mile And Lost Power Truck Would Only Go A Max...
Asked by
tina74
1 ANSWER
1997
DODGE TRUCK
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Replacement
