1985 Dodge Truck 1985 dodge w100 4x4 trans. problem
TIM351
  • 5 POSTS
Transmission problem
1985 Dodge Truck V8 Four Wheel Drive Automatic
I have a 1985 dodge w100 and it runs and drives ok but when you put it in drive it wont move but if you put it in 1st gear then it will start driving fine then shift it to 2nd then into drive and it will drive and pull down the road great, then when you come to a stop sign it will not move in drive again until u shift it into 1st again and up to drive. i changed the trans. filter and oil and no change. any ideas what it could be??
Apr 8, 2009 at 6:55 AM
  • 110,248 POSTS
It sounds like a stuck check ball in the valve body that needs manually overidden to work. The valve body will most likely need removed and cleaned and checked.
Apr 19, 2009 at 7:25 AM
TIM351
  • 5 POSTS
Is the valve body still the problem if it wont pull in any gear now?, not even reverse. one day it was driving fine and next day, it wont move at all
Apr 22, 2009 at 6:12 AM
  • 110,248 POSTS
Yes it could be the problem, but you will need a trans mechanic to check it.
Apr 22, 2009 at 9:23 AM
