1984 Dodge Truck REVERSE GEAR FIX
CMBREEDEN
Transmission problem
1984 Dodge Truck V8 Four Wheel Drive Automatic
I HAVE A 1984 DODGE 250 ROYAL PROSPECTOR THAT ABRUPTLY LOST REVERSE GEAR. NO PRIOR SLIPPAGE OR PROBLEMS. 1ST GEAR AND ALL FORWARD GEARS WORK FINE. SUGGESTIONS FOR FIX OR DIAGNOSIS?
Feb 15, 2010 at 8:39 AM
DR LOOT
  • 2,311 POSTS
there are two bands on that transmission that are adjustable from the outside it will be the forward ban it will have a big locknut on it you can't miss it, loosen up the band not in with your fingers tightened up the band and back off 1/2 turn then tighten the nut. try that and see if it helps.
Feb 19, 2010 at 2:33 AM
