1980 DODGE D-50 BACKFIRES AND SPUTTERS WHEN I ACCELLERATE
LUCKIECOWGIRL
  • 14 POSTS
1980 DODGE RAM D-50 2.6 LTR 5 SPD 130,000
TRUCK STARTS AND IDLES FINE ... WHEN I ACCELLERATE IT BACKFIRES AND SPUTTERS IT CONTINUES TO RUN BUT VERY ROUGH AND UNDRIVABLE .
SO FAR I HAVE REPLACED THE : PLUGS , WIRES, DISTRIBUTER CAP AND ROUTER AS WELL AS THE COIL .
THE TRUCK RAN FINE FOR 2 DAYS AFTER REPLACING THE COIL BUT THEN BEGAN DOING THIS..
ANY IDEAS :?: :?: :?: ??????????THANX :wink:
Oct 16, 2007 at 12:02 PM
BMRFIXIT
  • 19,053 POSTS
[quote:f78937108c="luckiecowgirl"]1980 DODGE RAM D-50 2.6 LTR 5 SPD 130,000
ANY IDEAS :?: :?: :?: ??????????THANX :wink:[/quote:f78937108c]
All the work you did and not a fuel filter
Check the fuel system
And ignition wires
Good luck
Oct 16, 2007 at 1:02 PM
LUCKIECOWGIRL
  • 14 POSTS
[quote:e360c0a557="BMRFIXIT"][quote:e360c0a557="luckiecowgirl"]1980 DODGE RAM D-50 2.6 LTR 5 SPD 130,000
ANY IDEAS :?: :?: :?: ??????????THANX :wink:[/quote:e360c0a557]
And ignition wires
Good luck[/quote:e360c0a557]
replaced fuel filter and replaced wires --
it doesn't seem like any fuel is getting to the carburator ???????
Oct 21, 2007 at 5:07 PM
LUCKIECOWGIRL
  • 14 POSTS
[quote:6c37babe22="Rodimus-Prime"]it could be a dud coil try a different coil and see if it remains.[/quote:6c37babe22]
thanks for u r reply !but i'm still stuck ...
replacing the coil was the 1st thing i did and the truck ran great for 2 days after that.
then it bogged down and began to backfire through the carb. it will idle fine but as soon as i accellerate it sputters and backfires so rough its undriveable.
Oct 22, 2007 at 9:55 AM
LUCKIECOWGIRL
  • 14 POSTS
[quote:1915fa2891="luckiecowgirl"][quote:1915fa2891="Rodimus-Prime"]it could be a dud coil try a different coil and see if it remains.[/quote:1915fa2891]
then it bogged down and began to backfire through the carb. it will idle fine but as soon as i accellerate it sputters and backfires so rough its undriveable.[/quote:1915fa2891]
when the truck is idiling with the air filter off looking into the barrells of the carb it appears to be dry as a bone ...the carb is an aftermarket mikuni
Oct 22, 2007 at 9:58 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e9b772a428="luckiecowgirl"][quote:e9b772a428="BMRFIXIT"][quote:e9b772a428="luckiecowgirl"]1980 DODGE RAM D-50 2.6 LTR 5 SPD 130,000
ANY IDEAS :?: :?: :?: ??????????THANX :wink:[/quote:e9b772a428]
And ignition wires
Good luck[/quote:e9b772a428]
it doesn't seem like any fuel is getting to the carburator ???????[/quote:e9b772a428]
CHECK THE FUEL PUMP
DO YOU HAVE FUEL PRESSURE
Oct 22, 2007 at 10:32 AM
