1979 Dodge Truck wont start
65,000 MILES • V8 • AWD • AUTOMATIC
YUKON JOE
79 150 pick up with a 318 wont start only has strong flashers but nothing else works right barely cranks has new battery voltage regulator ballist resistor i think it was called and i have no idea what to do next please help so i can get to and from work thank you and god bless.
Feb 21, 2010 at 11:59 AM
  • 75,988 POSTS
Do below and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Feb 21, 2010 at 1:13 PM
