1978 Dodge Truck Engine to transmission
DRSPOP3
Transmission problem
1978 Dodge Truck V8 Two Wheel Drive Automatic
I have a '78 Dodge Lil' Red Express Truck with a 360 engine and a 727 transmission.
I'd like to redo a 318 from a '76 dodge charger and put it in the truck.
Will the 318 bolt to the 727 transmission on the truck?
Mar 8, 2010 at 7:49 AM
HMAC300
  • 48,601 POSTS
this is a pretty simple swap as everything should bolt up. Bu ti don't know why you want to do t hat. Anyhow make sure to repalce the torque converter otherwise you get a big vibration as the balance is different between the two engines.
Mar 8, 2010 at 10:14 AM
