1977 Dodge Truck Truck won't move when put in gear
FRUSTRATEDCAROWNER
Transmission problem
1977 Dodge Truck V8 Four Wheel Drive Manual
When put in gear the truck won't go anywhere. I can completely release the clutch and it doesn't die either. I don't think the clutch is engaging.
May 11, 2009 at 3:23 PM
NURDGURL
transmission, universial joints, drive shaft, or the rear end, if it's a automatic, if it's a manual, then check your clutch,
Sep 7, 2009 at 2:20 AM
