Engine problem
1977 Dodge Truck V8 Wheel Drive Type unknown Automatic 210000 miles
it stalls when i stop, then takes about 10 minutes i can start again. then just 1 mile down the road it died again. happened 3 times. had a problem with the rods, had to replace one, and one seems as though its about 1/4 inch shorter then the rest. thought maybe the rocker was tightened to tight and that the cam was flattened. wondering if that could be the problem or just a electrical problem. thank you for your time.
Nov 30, 2007 at 9:44 AM
