We need to start at the power source, the battery. If it is fully charged, check to make sure the battery terminals are clean and tight. Also, make sure the ground to the engine block is clean and tight. Also, make sure the battery cables are in good condition and not corroded with acid which could cause a break in the electrical flow.
Let me know what you find.
SPONSORED LINKS
Friday, September 3rd, 2010 AT 11:22 AM
