1976 Dodge Truck cranking over starting
PAINTERLOU
Engine Mechanical problem
1976 Dodge Truck V8 Two Wheel Drive Automatic
my truck will not crank over with out a jump .it has a brand new battery.the ign. coil get very hot quick.need info and voltage spec.for coil and voltage regulator
Apr 15, 2010 at 8:51 AM
  • 75,988 POSTS
Check and test the ignition ballast resistor, coil and starter
Apr 15, 2010 at 8:58 AM
