1975 Dodge Truck transfercase popping
138,000 MILES • V8 • 4WD • MANUAL
STEWBACCA3507
I have a popping sound coming from under the truck in the area of the transfer case and transmission. I suspect a u-joint is going bad because the sound only happens under hard acceleration. As well there is no stalling or jerking related to the popping. There is damage to the frame rail that passes underneath the transmission and transfer case but I could not find any scarring or indication of damage to the transfer case itself.
Dec 18, 2008 at 5:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
Universal joints is usually the common culprit in this situation. However, before replacing the u-joints I suggest listening closely to the transfer case motor. In some instences, the motor actually makes a clicking type noise when it is faulty, which means the noise will come from inside of the case.
Hope this helps..
Thanks for using 2carpros.com!
Dec 18, 2008 at 5:41 PM
