stratus squeaking
SKENNEDY
I have a 1997 dodge stratus. It has 174 kms on it.It is a 16 valve 2.4 litre dual overhead cam. I just recently started to notice the car was squeaking while going over bumps. Does the car need just a lube job or worse?
Apr 12, 2007 at 4:48 AM
STEELWORKER
  • 12 POSTS
check the rubber boots around the lower ball joints. They are probably shot. This was a recall issue, and the ball joint and lower control arm is one assembly, about $200.00 a side.
May 2, 2007 at 3:59 AM
