Engine stalls when I turn wheel at low idle. Chck light on.
DODGE STRATUS
CLETUS1821
I have a 2001 Dodge Stratus 4 cyl 2.4 with 135,000 miles. It stalls each time I turn the wheel while in idle either in park or with the transmission engaged. If I apply gas it does not stall. A day after this started the check engine light came on. Any clues?
May 29, 2007 at 12:39 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it could be the Idla Air Control Valve. It adjusts idle, and the PCM can see the load of the p/s pump and should adjust idle accordingly
May 29, 2007 at 1:09 AM
CLETUS1821
Is this the AAS motor? and How much of a job is it for someone who does not have a ton of experience under the hood but is very patient?
May 29, 2007 at 1:59 AM
2CARPRO JACK
  • 11,533 POSTS
AAS motor? IAC ISC motor
May 29, 2007 at 2:52 AM
CLETUS1821
Turned out to be the PCM, or at least that is what the error code said. P0601. Is there really a way to wipe out the stored codes by disconnecting the negative terminal and holding the ignition for 20 seconds? Is it even worth the effort?
May 29, 2007 at 5:22 AM
2CARPRO JACK
  • 11,533 POSTS
not worth it, they will reset if there isnt any problem
May 29, 2007 at 5:54 AM
