1995 Dodge Stratus Door Key Won't Turn
ISABEL08
I have a 95 dodge stratus. My door keys stopped working, when you put the key in the door nothing happens, it doesn't even turn. I first I thoungt it might have been becuase of the cold days we had and the locks just froze, I tried spraying some d-icer,wd but the key doesn't turn,
Mar 11, 2007 at 7:03 AM
BOOTDOG
  • 665 POSTS
try spraying with wd-40. if that doesn't work, and the key doesn't work in all door locks then the key is worn out. if it works in all the door locks but one then the door cylinder is worn out.
Mar 11, 2007 at 8:01 AM
Suggested Repair
Spray WD-40 into the lock. If the key still will not turn in any door, the key is worn and should be replaced. If it works in the other doors but not one, that door lock cylinder is worn and should be replaced.
Conversation Summary
Owner of a 1995 Dodge Stratus says the door key will not turn, even after de-icer and lubricant, and first suspected frozen locks. Expert advises WD-40, then checking whether the key fails in every door: all locks points to a worn key, one lock points to a worn cylinder.
