The heater resister is behind the passenger side foot kick pannel. Remove the pannel and look up to the heater box it is held inplace with two screws. After you replace the resister and start the blower up you will smell somthing like wires burning. It is the oil from shipping burning off so run in all speeds to get them off. Also if the resister burns out again the blower fan need to be replaced.
Good luck with this it should only take you about 15 min to replace the resister.
SPONSORED LINKS
Monday, October 8th, 2007 AT 5:14 PM
