Car squeaks
MISSY.NESTO
2001 Dodge stratus coupe. I have a squeaking that dose not stop. I just put new struts and tires and the alignment. It doesnt make the noise when im driving its when i change gears and as the car pulls off it squeaks not continuosly it goes away after i put the 2nd gear and so forth. What can this be ?
Oct 29, 2007 at 9:05 AM
BLACKOP555
  • 10,386 POSTS
where does the squeakign sound come from. does it come when car is idling.
also push the brakes down while driving does it still squeak? if not i belive you may need new brakes. also sometimes the dust guard is bent sometimes causing a squeaking sound.
if its coming from the engien i would check the drive belt.
Oct 29, 2007 at 3:00 PM
