20Amp Ignition,fuel,starter fuse under hood keeps blowing
1920 DODGE STRATUS
TAM65
I have a 1996 Dodge Stratus 2.4L with 113,000 miles.The 20 Amp ignition fuse under the hood keeps blowing. There doesn't seem to be any regular occurance that happens before the fuse blows. I replace the fuse and it blows again, i can replace anywhere from one to ten fuses and all of a sudden it will start. A guy at the local Auto Zone told me there is a problem with the wiring harness in this model. He claims it comes out of the fire wall and makes a sharp turn down and then back up again causing it to short out. Does anybody have any tips or have they ever had this problem before????
Nov 29, 2007 at 9:53 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9a219342f3="TAM65"]I have a 1996 Dodge Stratus 2.4L with 113,000 miles.The 10 Amp ignition fuse under the hood keeps blowing. There doesn't seem to be any regular occurance that happens before the fuse blows. I replace the fuse and it blows again, i can replace anywhere from one to ten fuses and all of a sudden it will start. A guy at the local Auto Zone told me there is a problem with the wiring harness in this model. He claims it comes out of the fire wall and makes a sharp turn down and then back up again causing it to short out. Does anybody have any tips or have they ever had this problem before????[/quote:9a219342f3]
Can you tell us what fuse you are dealing with?
What circuits does it control?
Nov 30, 2007 at 3:21 PM
