HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Stratus
Ignition
No Spark
SPONSORED LINKS
1996 Dodge Stratus No fire from the ignition coil
JOSE BANDA
MEMBER
1996 DODGE STRATUS
Electrical problem
1996 Dodge Stratus 4 cyl Front Wheel Drive
I have replaced the ignition coil, relay, and there is still no fire from the ignition coil. Cranks over but wont start
Friday, August 22nd, 2008 AT 11:09 PM
MECHANIC
Test the ASD Relay and Crankshaft Position Sensor-
SPONSORED LINKS
Saturday, August 23rd, 2008 AT 10:57 AM
HYDRODUDE
MEMBER
Same problem here except I replaced the crank and cam sensors, coil pack, and MAP sensor.
Thursday, December 18th, 2008 AT 3:18 AM
MECHANIC
Double check the DIS module and CPS circuit
Thursday, December 18th, 2008 AT 1:33 PM
Please
login
or
register
to post a reply.
Related No Spark Content
1996 Dodge Stratus 96 Dodge Stratus No Spark
Car Just Quit On Me When I Was Driving Still Had Batteri Power Then Checked For Spark And No Spark And No Power Going To The Wire Harness To...
Asked by
joe-tibbetts
1996
DODGE STRATUS
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
1996 Dodge Stratus No Spark
Car Ran Fine, Put It In Barn To Do Regular Tune Up And See Why The Car Was Running A Little Rough. Started Car One Day And It Arched In...
Asked by
Emmie1777
1 ANSWER
1996
DODGE STRATUS
1996 Dodge Stratus No Spark On Fourth Cylinder
My 1996 Dodge Stratus Does Not Have Spark On The Fourth Cylinder. Can This Be Attributed To Faulty Coil Pack Or Pcm Module? Is There A Way...
Asked by
Jeryy
1996
DODGE STRATUS
No Spark. I Think It Has A Electronic Distributor?
I Am Working On A 98 Dodge Stratus 2.5v6 And There Is No Spark. I Think It Has A Electronic Distributor, I Had The Cap Off And Replaced The...
Asked by
j.stieg
1 IMAGE
1998
DODGE STRATUS
What Would Cause No Spark And No Power To The Fuel...
I Was Driving My Car To Work And It Died. It Started Back Up And Did Fine. When I Got To Work And Parked, And Turned The Car Off, I Tried...
Asked by
buddhaluv79
1 IMAGE
1995
DODGE STRATUS
VIEW MORE
SPONSORED LINKS
Ignition Coil System Test Repair - All Cars
Ignition System Testing
Crankshaft Sensor Replacement
Online car repair manuals
