2006 Dodge Stratus Why does the front end shake so badly?
80,000 MILES • 6 CYL • AWD • AUTOMATIC
MOMMYJEN08
I have a 2006 Dodge Stratus. The front end shakes horribly bad once I hit about 55/60 mph and continues to get worse through 75 mph, after that it slows down. My husbands seems to think it may be the inner cv joints because we already replaced the wheel barings and it didn't do any good. If anything it got slightly worse. What could it be? Every mechanic I have taken it to tells me there is nothing wrong, but there again they won't take it for a drive either.
Nov 10, 2008 at 5:50 AM
ZACKMAN
  • 4,202 POSTS
You have to take it to a shop specializing in wheel alignment. It is not your inner CV joint, it sounds more likely to be either bad inner and/or outer tie rod ends, lower maybe even upper ball joints, and/or bad tire and/or bent wheel.
Nov 10, 2008 at 3:44 PM
