2006 Dodge Stratus Cruise Control Malfunction
51,700 MILES • 4 CYL • 2WD • AUTOMATIC
KRISTICTO
My cruise control started to malfunction about a month ago. The cruise light will come on but will not set and will go off after pressing 'set'. I have had the servo speed controler and PCM replaced today. It worked after leaving the dealership today but now is doing the same thing. Any ideas?
Jun 4, 2008 at 4:54 PM
TWINKEY1
  • 49 POSTS
had the same problem on my 2003 dodge stratus found out it was a bad brake switch,so you might wanna check there
May 30, 2009 at 2:17 AM
