2006 Dodge Stratus
HECTORMIKE
Air Conditioning problem
2006 Dodge Stratus 6 cyl Two Wheel Drive Automatic 85.000 miles
water on passenger side floor. is it from a clogged ac tubing and how to fix the problem
Jul 29, 2010 at 11:32 AM
  • 110,248 POSTS
That is what it sounds like unless it is coolant. As far as water, open the hood and look on the firewall, passanger side. You will see a black rubber tube pointing toward the ground. Usually, they get clogged at the end from dirt and debrit from the road.
Let me know if you find it.
Aug 6, 2010 at 5:21 PM
