2006 Dodge Stratus
AD142314
  • 6 POSTS
Engine Performance problem
2006 Dodge Stratus 4 cyl Front Wheel Drive Automatic
300,3002, and 2074 codes are present and the engine idles rough and cuts off when i come out of a stop at a stop sign or light ect.
Nov 25, 2009 at 9:44 PM
MERLIN2021
  • 17,250 POSTS
Codes seem a bit funky, could they bee P0300=random misfire, P0302=misfire cylinder 2
P2074 not found, Your last tune up was? And check fuel pressure.
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
https://www.2carpros.com/dia/how_to_check_compression.htm
https://www.2carpros.com/dia/index.htm
If you could give the engine size and body style, it will help with any more questions!
Nov 26, 2009 at 12:54 AM
