2005 Dodge Stratus oil smell
83,000 MILES • 6 CYL • 2WD • AUTOMATIC
MWALTHERS
I had my oil changed 3 weeks ago and smelled burning oil, so i took it back to jiffy lube, they said there was a slight leak under where the oil filter was and they tightened it. I then noticed oil was leaking from the fill cap so i replaced it. i still smell oil after the car runs awhile but not as strong and there is slight oil around the fill cap. any ideas
Dec 9, 2009 at 1:17 AM
BLACKOP555
  • 10,386 POSTS
check the level may be overfilled. also you may have odors in your vents and cabin air filter along with in the engien compartment. it all has to burn off !
Dec 9, 2009 at 1:07 PM
