2005 Dodge Stratus HELP !
45,000 MILES • 4 CYL • FWD • AUTOMATIC
MYKLASIX
Hello, I have a stumper for you guys. The above mentioned car works perfect in every way. The heater even works fine blowing out strong HOT air...
( unless the headlights are on ) then it blows out pure cold air. turn off the lights, and bam...back to hot air again?????? please help.
Oct 1, 2009 at 1:30 PM
MATHIASO
  • 1,209 POSTS
this is electrical it will require looking for a short to power between circuits and because there is not blown fuse.
wirring diagram, looking into connetors.. and testing with multimeter.
I believe the problem is not the heater.
you will be chasing a short in the circuit.
Oct 2, 2009 at 3:08 PM
