2005 Dodge Stratus fan
KAMIGIRL
2005 Dodge Stratus
my fan goes on and off when i turn the car off and is draining my battery
Sep 22, 2009 at 1:43 PM
BMRFIXIT
  • 19,053 POSTS
Suspect and check relay
do a code check too
Sep 22, 2009 at 11:14 PM
KAMIGIRL
[quote:e5789131c5="BMRFIXIT"]Suspect and check relay
do a code check too[/quote:e5789131c5]
Thank you and I will try to get that done somehow...Can I do that myself...
Sep 23, 2009 at 5:40 AM
BMRFIXIT
  • 19,053 POSTS
Mark and switch relays if that fix it replace the relay that was controlling the fan
as we dont wont the problem to switch to a different area or system
to check for codes
cycle key on off on off on
read in the odometer area P000 ----- DONE
codes
Sep 23, 2009 at 9:14 AM
