2005 Dodge Stratus Cloged drain tube
53,000 MILES • 4 CYL • 2WD • AUTOMATIC
DEBBIEDOO
The drain tube for the a/c is cloged and the condensation is draining into the passenger side. Is there easy access to unclog this tube? I looked under the hood, but it seems that I might not be able to get at it from above.
Aug 30, 2010 at 12:47 AM
  • 110,248 POSTS
It is much easier from the bottom. The drain is connected to the firewall. It is a rubber hose pointing down toward the road. Usually, they get clogged at the end.
Sep 1, 2010 at 6:42 AM
