2004 Dodge Stratus Popping/Knocking and Grinding Noises
48,000 MILES • 4 CYL • FWD • AUTOMATIC
KNYGHT23
I have recently started having various knocking and grinding noises coming from the front end of my Dodge Stratus, along with squeaking when riding over bumps or rough roads. The knocking and grinding noises aren't constant; there are times whenever I drive the car and I don't hear them, but whenever they start, they continue until the car comes to a rest. I've taken the car into a mechanic and they replaced two "ball joints" and the noises stopped for several days, but have recently resurfaced. What could the noises be?
Feb 9, 2008 at 8:33 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d820c244fb="knyght23"]Engine problem
2004 Dodge Stratus 4 cyl Front Wheel Drive Automatic 48,000 miles
I have recently started having various knocking and grinding noises coming from the front end of my Dodge Stratus, along with squeaking when riding over bumps or rough roads. The knocking and grinding noises aren't constant; there are times whenever I drive the car and I don't hear them, but whenever they start, they continue until the car comes to a rest. I've taken the car into a mechanic and they replaced two "ball joints" and the noises stopped for several days, but have recently resurfaced. What could the noises be?[/quote:d820c244fb]
Check stabilizer bar bushing and links
Feb 11, 2008 at 11:22 AM
KNYGHT23
Had it taken to a Dodge certified garage, and the garage foreman checked the suspension out, checked the bushings, the links and the anti-sway bar. The links were worn and were replaced, but the car continues to make the noise on and off. Unfortunately the car would not reproduce the sound while the mechanic was there or driving it so we were both left scratching our heads.
Feb 12, 2008 at 8:04 AM
