2004 Dodge Stratus o2 sensor
82,700 MILES • 4 CYL • 2WD • AUTOMATIC
DODGESTRATUS04_GUY81
my car is dieing out in park at idle speed.. it either dies out or studders when put in reverse or drive when i have my climate control on.. is it that maybe my o2 sensor is bad or what could be the problem if it is the oxygen sensor how many is there on the 2.4L 16 valve DOHC?
Jan 10, 2008 at 7:37 AM
BMRFIXIT
  • 19,053 POSTS
[quote:70b36c086d="dodgestratus04_guy81"]2004 Dodge Stratus 4 cyl Two Wheel Drive Automatic 82,700 miles
my car is dieing out in park at idle speed.. it either dies out or studders when put in reverse or drive when i have my climate control on.. is it that maybe my o2 sensor is bad or what could be the problem if it is the oxygen sensor how many is there on the 2.4L 16 valve DOHC?[/quote:70b36c086d]
do you have check engine light on?
O2 sensor will not cause the stalling
check for a vacuum leak
idle problem
Jan 10, 2008 at 12:26 PM
