2004 Dodge Stratus location of drain plug on radiator
2004 DODGE STRATUS
119,000 MILES • 4 CYL • FWD • AUTOMATIC
DADDIOKOOL
not sure where the drain plug is located .. leaking from the corner of driver side radiator. Hoping its just a loose drain plug!
thanks for the help
Jun 19, 2010 at 10:48 AM
MERLIN2021
  • 17,250 POSTS
The drain is on the bottom, but it doesn't normally loosen by itself, Autozone will loan you a cooling system pressure tester, test the pressure, this will expose leaks real fast. Could be a side tank seal.
Jun 19, 2010 at 11:17 AM
