2004 Dodge Stratus Help-REAR Driver Side Suspension
78,300 MILES • 6 CYL • FWD • AUTOMATIC
NICKBALLA
Hello, I received a blow out today and the way the tire was cut and the way the donut fits on the rear driver side it seems something more than just a tire change is needed. I take it in to get a replacement tire and was told that the rear driverside control arm was split or cracked and so it didn't make sense to place a new tire on because it would cut into the new tire. Is there a such thing as a Driver side rear wheel control arm? What part could/would I need to get to repair this problem? Whats a ball park amount it will cost? Do I need to NOT drive the car until its fixed? it sounds like its rubbing on my donut spare tire.
May 26, 2009 at 4:07 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_363.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_168.jpg
also Was the spring checked I would suspect spring ***************************************** need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 27, 2009 at 10:31 PM
