2004 Dodge Stratus front right Collision
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
PHILLIP CARTER
i was in a accident which my front right side was damaged and will need to be completely repaired, I also busted both front tires.
what type of under pending or suspension axle or any other type of repair should be checked before I sign a release
Jul 27, 2010 at 9:16 AM
  • 110,251 POSTS
That is a tough one without seeing the vehicle. Make sure the strut towers were not damaged, hub bearings, CV joints and axles, transmission housing, output bearing in the transmission and the list goes on. Was there any damage under the hood?
Aug 6, 2010 at 5:47 PM
