2004 Dodge Stratus ENGINE MALFUNCTIONS
94,778 MILES • 6 CYL • FWD • AUTOMATIC
VOLVONIC S-70
  • 5 POSTS
CAR HAS BEEN CECKED AT AUTO ZONE FOR "CHECK ENGINE" LIGHT. IT HAS MULTIPLE ENGINE MISFIRE, THE BACK THREE CYLINDERS PLUGS SEEM TO FIRE OK, THE FORWARD THREE PLUGS ARE ALL SUDDY AS IF THEY ARE LOADING UP AND FOULING OUT.
Jun 22, 2010 at 1:52 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jun 22, 2010 at 7:26 PM
