2003 Dodge Stratus sway bar end links
78,000 MILES • 6 CYL • FWD • MANUAL
ALYSIA
I brought my car to the dealership to have diagnostics done on it because the guages weren't working. I was told that it is the cluster behind the dash that is bad and it doesn't effect anything else with the car. But that is not my question. I have this terrible noise that sounds like something is breaking apart when I go over bumps and around corners, on the front passenger side. I was told that it is the end links on the swaybar, I am guessing in the front because the noise comes from the front passenger side. I want to upgrade the suspension on my vehicle because it sucks overall. Should I start with swaybars? If I just fix the endlinks could I keep the stock swaybars and just change out struts and shocks?
Mar 30, 2008 at 10:40 AM
BMRFIXIT
  • 19,053 POSTS
Its your money you can do it any way you want
but may I suggest do it all at once its cheaper and easier
and also check the bar bushings too
Mar 31, 2008 at 12:50 PM
