2003 Dodge Stratus R/T
CPIZNEE
  • 2003 DODGE STRATUS
I need help. My Stratus wouldn't start. It wouldn't even turn over. I bought a new battery and now it starts but as soon as I let my foot off the gas it stalls. I saw that someone else in the forum had the same issue but no response. I replaced the TPS but that didn't work. I had the mechanics hook up a computer but no results. Whats next? Help!
Friday, August 11th, 2006 AT 11:36 PM
CPIZNEE
I cleaned my throttle body and it works fine. If you have this problem buy throttle body cleaner. Open up the blade get a toothbrush and scrub it clean. Make sure the cleaner is safe for O2 sensors. I opened it up and sprayed scrubed, sprayed scrubed. I used half the can.
Disclaimer: The information above is only a form of opinion from my own past experiences. I am not responsible in any way if you decide to use my opinions on your personal vehicles. You may have other problems that may contribute to the stalling. For this and other reasons, I only post the above information as a shared experience. You should always consult your dealership before performing any work that may possibly void your warranty.
Thursday, August 17th, 2006 AT 7:05 PM
